Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
Don, I have been a major fan of the Poser Sketch feature for years. It was in fact the main reason I got Poser years ago. I have also collected some nice free sketch pre-sets over the years, have modified some of them, and the results are stunning. In fact Poser was originally meant to be an artist's tool to work with then Fractal Design's Painter. But hardly anyone seems to use them or post artwork with them. I believe I may have been the first person to discover and report back to MetaCreations the work-around to get higher-rez sketch renders out of Poser using the Make Movie feature. Yet hardly anyone seems to do much with it. The sketch features are great, but I think 90% of the Poser user base (at least among males) uses Poser to render nude girls with huge boobs and detailed vaginas and weird monsters (That should make some people out there excited and upset...) I have certainly done my share, heh heh...
Milamber- 1. Make sure you have Poser set up to do a Sketch Render of your choice (render one just to be sure) 2. Go To Animation Setup, select a frame size of 2048 x 1024 (or whatever ratio you like) Make Frame Rate and Frame Count as "1" 3. Go to Make Movie, select Sequence Type as "Image File" Resolution "Full", Quality "Current SKETCH setting" Select Use This Frame rate as "1" 4. Poser will ask you what to name the file and the save file format (I use PSD because I do post work in Photoshop) That should start it going. After it is done rendering, open it up in Photoshop and you can rez-it up to 4K or whatever and apply other filters like sharpening, etc. I sometimes even apply other texture backgrounds and other Photoshop filters. The end result is VERY MUCH like "real art"
