Fri, Feb 7, 2:38 AM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Are you up to the challenge??
Subject: Apllying graphics on a path
Gregpktm ( ) posted Sun, 01 May 2005 at 6:07 PM · edited Thu, 06 February 2025 at 11:55 PM
In Illustrator or Photoshop, how can I apply an image on a path? (For example like applying text on path)
I'm trying to create sidewall of a tire and I want to achieve something like the image above. I already tried "bend" but this command trasforms the image also except from bending it.
Message edited on: 05/01/2005 18:08
aprilgem ( ) posted Sun, 01 May 2005 at 6:27 PM
There's a specific tool for that in Illustrator, and it's fairly easy to figure out -- just draw out the path, or create a circle, select the tool, click on the path and voila, you should be able to type on it. As for Photoshop, the Create Warped Text seems to work okay if you fiddle with the settings enough. Simply type out the text, go to the top toolbar where you see the T on a bent path (with three dots) icon, click that, and fiddle with the settings under the Arc style option. There might be better ways, but I have old version of both programs and don't know them. Hope this helps! :)
Gregpktm ( ) posted Sun, 01 May 2005 at 6:51 PM
I know how to do it with a text. but I want to apply a drawing on a path, not text.
aprilgem ( ) posted Sun, 01 May 2005 at 7:44 PM
Oh, oops! I'm sorry. I completely misunderstood. That's an even tougher question, then. Hm. I'm not sure if this is in Illustrator or Freehand, but there's an "envelope" tool that allows you to warp images to a particular shape. And in Photoshop, I would use Polar Coordinates to do what you want to do. I'm attaching an image to show the before and after using that tool.
Gregpktm ( ) posted Mon, 02 May 2005 at 7:38 AM
Thanks aprilgem. Maybe it's not 100% what I wanted, but it helped me a lot. I'll use that method. Thanks again for your help.
retrocity ( ) posted Mon, 02 May 2005 at 7:47 PM
it's a tough effect to get with the "pixel" based app like PS... Illustrator or even Flash seems better suited to use in conjunction with PS. :) retrocity
aprilgem ( ) posted Mon, 02 May 2005 at 8:33 PM
Yeah, what retrocity said. :) I thought of another way to do it in Illustrator, btw. Make the graphic a brush, make a circle, then apply the brush to the circle. You should get the same effect as in my sample. I've done it with a celtic brush pattern I made a long time ago, so I know it works. ;)
Gregpktm ( ) posted Tue, 03 May 2005 at 7:49 PM
Can I ask comething else? How can I convert a shape to a path? I created a circle but when I try typing on it, does not doing anything. (I talking about Illustrator, in Photoshop I know how to do it)
dreamer101 ( ) posted Tue, 03 May 2005 at 8:32 PM
Your shape has a path. In Illustrator you need to use the "Type on a Path Tool" if you want to type around the circle. If you want to type within the circle then you use the "Area Type Tool".
