while it may be invisible from one direction it will render both sides,Poser prefers this to a 2 sided plane where you'll get the above zfighting. if in P5/6 make sure backface cull is off(which I think it is by default anyway) Cheers Stefan
Wow. Looks innocuous enough, doesn't it? I assume that you tried the single sided version in P4 with the same result? I can't imagine what's causing that. I can see the three default lighting colours in there, which may be a clue... I'll think about this during the day. Maybe someone else will have an inspiration.
How did you map it in UVMapper? Planar or what? It looks like each polygon has it's own mapping or something :o/
I am remmapping right now as a single sided, and with much better results. I used box mapping (I didn't like the perspective lines give when planar). I can get used to the invisible from one angle thing I guess. Just so odd that UV shows the original perfect with or without textures and Poser turns it into abstract art with no texture. /shrug Thanks for all the help. :) JDexter
Poser interprets a mesh in wildly different ways sometimes. ;) If you truly want it to be double sided, you can do that as long as you make it a "shell" - i.e. with a small thickness between the two faces. This may be unacceptable in terms of the mesh size, but it makes it easier to handle within Poser.
I just made a set of wings that were flat and one sided, because I rembered that funky problem shown above I exported them as one sided from the modeler. but they drove me crazy to work with in poser, so I made them double sided using uv mapper pro,and they work just fine in p5,both sides are visible without the weirdness that modeling them double sided produces. -3DZ
Funny YouTube video of the week - Bu De Bu Ai
I did the reverse winding and it was still invisible from one side. It's okay, I am able to use it just fine as single sided now.
3DZ, it's funny, but the first examples I gave were in P4 and P6, I tried it in P5 and it looked just like the P6 version.
Maybe it was especially bad in this case because there was a curvature in the plane I created (pretty substantial at the ends) that you really can't see in the pictures.
Either way, I did learn something, and am grateful for all the help.
Now I just have to get used to the 'invisible from one side thing' ,hehe.
JDexter
