Sat, Jan 25, 2:41 PM CST
Subject: Imported object oddness
JDexter ( ) posted Thu, 05 May 2005 at 7:00 AM · edited Sat, 25 January 2025 at 1:23 PM
I created a simple curved plane in Carrara, mapped it in UV Mapper Pro, and it looks great in UV, both ith and without textures. When I import it into P6 (and then P4) it is just awful. Anyone have any idea why this is happening? JDexter
JDexter ( ) posted Thu, 05 May 2005 at 7:02 AM
This is the P4 import. JDexter
stonemason ( ) posted Thu, 05 May 2005 at 7:16 AM
is it double sided?
Cg Society Portfolio
JDexter ( ) posted Thu, 05 May 2005 at 7:19 AM
It is two-sided, yes. I tried it single sided also, but single sided it is invisible from one direction. JDexter
stonemason ( ) posted Thu, 05 May 2005 at 7:21 AM
while it may be invisible from one direction it will render both sides,Poser prefers this to a 2 sided plane where you'll get the above zfighting. if in P5/6 make sure backface cull is off(which I think it is by default anyway) Cheers Stefan
JDexter ( ) posted Thu, 05 May 2005 at 7:27 AM
Thanks! I'll give that a try. JDexter
EnglishBob ( ) posted Thu, 05 May 2005 at 7:27 AM
While P5 and P6 don't like double sided polygons (despite the presence of a double sided square prop in the library), Poser 4 should be alright with them, so that doesn't explain the weirdness in your second picture. May we see a wireframe view? That might help...
JDexter ( ) posted Thu, 05 May 2005 at 7:43 AM
This is the wireframe in P4. JDexter
EnglishBob ( ) posted Thu, 05 May 2005 at 8:01 AM
Wow. Looks innocuous enough, doesn't it? I assume that you tried the single sided version in P4 with the same result? I can't imagine what's causing that. I can see the three default lighting colours in there, which may be a clue... I'll think about this during the day. Maybe someone else will have an inspiration.
TrekkieGrrrl ( ) posted Thu, 05 May 2005 at 8:02 AM
How did you map it in UVMapper? Planar or what? It looks like each polygon has it's own mapping or something :o/
JDexter ( ) posted Thu, 05 May 2005 at 8:07 AM
I am remmapping right now as a single sided, and with much better results. I used box mapping (I didn't like the perspective lines give when planar). I can get used to the invisible from one angle thing I guess. Just so odd that UV shows the original perfect with or without textures and Poser turns it into abstract art with no texture. /shrug Thanks for all the help. :) JDexter
EnglishBob ( ) posted Thu, 05 May 2005 at 8:11 AM
Poser interprets a mesh in wildly different ways sometimes. ;) If you truly want it to be double sided, you can do that as long as you make it a "shell" - i.e. with a small thickness between the two faces. This may be unacceptable in terms of the mesh size, but it makes it easier to handle within Poser.
Berserga ( ) posted Thu, 05 May 2005 at 9:21 AM
I had the exact same problem with the exact same kind of prop (It was going to be an environment for outside a window. at the time nobody could help me. Glad to see you got help. :D
dan whiteside ( ) posted Thu, 05 May 2005 at 11:55 AM
JD - try loading it into UVMapper and export with "reverse winding" option selected. This often fixes invisibility problems (but not always!)
The3dZone ( ) posted Thu, 05 May 2005 at 1:41 PM
I just made a set of wings that were flat and one sided, because I rembered that funky problem shown above I exported them as one sided from the modeler. but they drove me crazy to work with in poser, so I made them double sided using uv mapper pro,and they work just fine in p5,both sides are visible without the weirdness that modeling them double sided produces. -3DZ
Funny YouTube video of the week - Bu De Bu Ai
JDexter ( ) posted Fri, 06 May 2005 at 6:03 AM
I did the reverse winding and it was still invisible from one side. It's okay, I am able to use it just fine as single sided now.
3DZ, it's funny, but the first examples I gave were in P4 and P6, I tried it in P5 and it looked just like the P6 version.
Maybe it was especially bad in this case because there was a curvature in the plane I created (pretty substantial at the ends) that you really can't see in the pictures.
Either way, I did learn something, and am grateful for all the help.
Now I just have to get used to the 'invisible from one side thing' ,hehe.
JDexter
