Sat, Jan 18, 10:55 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 7:20 pm)
Subject: why aint this morph working
nyguy ( ) posted Thu, 05 May 2005 at 5:28 PM ยท edited Sat, 18 January 2025 at 10:54 PM
Trying to create a simple light saber with an on/off morph but it ain't working.
Poserverse The New Home for NYGUY's Freebies
nyguy ( ) posted Thu, 05 May 2005 at 5:29 PM
here are each object
nyguy ( ) posted Thu, 05 May 2005 at 5:33 PM
here is with the morph applied same number of verts.
ockham ( ) posted Thu, 05 May 2005 at 6:16 PM
Most likely your modelling program rearranged the verts, even though the number is the same. Wouldn't it be easier to make the light a separate part, and turn it on and off by scaling?
My python page
My ShareCG freebies
nyguy ( ) posted Thu, 05 May 2005 at 7:02 PM
Yes it would be easier, but what is the fun in that?
Little_Dragon ( ) posted Thu, 05 May 2005 at 7:51 PM
If you're using Poser 6 (which seems unlikely, judging from the smoothing on those meshes), you could try enabling the "attempt vertex ordering correction" option when loading the morph target. Are you familiar with Poser's magnets and the grouping tool? A blade-hiding morph can easily be created with those.
nyguy ( ) posted Thu, 05 May 2005 at 9:11 PM
I am using P6, used UVmapper to get the smoothness in the meshes. Tried "attempt vertex ordering correction" the first time got the same, so I unchecked it, nada. Also tried using Pmorph after making the object into a figure, nada again.
nyguy ( ) posted Thu, 05 May 2005 at 10:17 PM
I finally got it to work, figured it out! I desided to gave Pmorph another go, just took the leading faces of the blade and streched it out to where I wanted it. In a few days I might add it to the free stuff after I get the textures refined.
Thanks for the suggestions.
Message edited on: 05/05/2005 22:17
