Mon, Jan 6, 10:21 PM CST
Subject: P6 Large Library thumbs
mask2 ( ) posted Sun, 08 May 2005 at 1:10 PM ยท edited Mon, 06 January 2025 at 10:18 PM
Hello, I've noticed that Library Thumbnails in P6 have a larger vertical spacing than in P5, so that You have to scroll a little more during Your daily library search... Is there a way in P6 to shrink the vertical spacing and get back to the nice and compact P5 thumbs look? Thanks for the info! Greets Mario
momodot ( ) posted Sun, 08 May 2005 at 1:17 PM
This is buging me too... and I hate the folder icons but I wish I could get rid of those without loosing the library item icons.
onimusha ( ) posted Sun, 08 May 2005 at 6:56 PM
This annoys me as well... A pretty obvious non-improvement... I'm surprised they made this change...
JeffH ( ) posted Sun, 08 May 2005 at 7:30 PM
The format seems to have been changed to accommodate the new thumbnail collapsing feature in General Preferences.
You can choose to collapse thumbs when the library exceeds a certain number of files.
-J.
mask2 ( ) posted Mon, 09 May 2005 at 6:22 AM
JeffH, does it means that if I set the number of files to, say 5.. I would get back to the old P5 look? I'll try when I'm back home...
momodot ( ) posted Mon, 09 May 2005 at 8:30 AM
On my machine it does not load the thumbnails at low settings for this but the space occupied by the "blank" thumbnail place holder is just as big as the thumbnail would be, just fatser to load... in other worrds the thumnails are not "colapsed" they are simply not loaded... but each libray item takes as much vertical space as it would with the icon loaded.
JeffH ( ) posted Mon, 09 May 2005 at 8:59 AM
"but each libray item takes as much vertical space as it would with the icon loaded. "
The question mark is a bit smaller than a thumbnail.
At the minimum screen resolution for P5/P6 I can see 4 1/2 thumbnails at a time - collapsed I can see 5 1/2.
I don't think the old P5 library format can be restored in P6 with this setting.
mask2 ( ) posted Wed, 11 May 2005 at 9:01 AM
Curious Labs hates us...
ebbtide ( ) posted Tue, 24 May 2005 at 2:26 AM
I've actually made large thumbs in P5 just by saving renders over the original library .PNG file. I would assume (don't have it yet--shipping) P6 will let you do the same in reverse. I believe the standard size poser png was 91x91 pixels, So presumably if you save a render in that size--or photoshop the big ones down--you should be able to get any size you want. As I say though, I haven't actually tried this on P6 yet, and there may be an easier way built in.
Hope this helps.
