Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Feb 24 4:38 pm)
nam era with holes ...that would be good :) glass..yes... perhaps that tex could be adapted for that torn up metal penetration
Humankind has not
woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound
together.
All things connect......Chief Seattle,
1854
Attached Link: http://theminiaturespage.com/boards/msg.mv?id=31835
here's a blurb that explains pretty much what happened...small arms fire. I used to work on low flying aircraft..they often came back with holes through the bottom...also sides, but they were at an angle coming from the ground... usually just a round hole where the bullet goes through... they used to rivet a small round disk to cover the hole...size of a silver dollar or so... rarely windshield hits...of course the hueys took more ground based fire when they went in, as did the planes...but mostly from groundfire while flying...
Humankind has not
together.
1854
Dave-So. Thanks. I'll look at that when I get back. Take it from your post ex-service ? JFandL. You could be right on both points. While theres offical standards and paint charts. In the real world nothing was ever that precise. I recall painting a bailey bridge from one end and met the other lads in the middle. Same cans of paint from the same truck, but a two-tone bridge. Al
meselfr: Thanks. Little_Dragon: OK. To the best of my knowledge and references is that just the red cross on 3 white panels on side doors and front ? William: More than. The "super seam guide" with panel, rivets and guide lines took nearly 3 days! With this you'll be able to do a camo map within hours. Plus the seam guide has an easy to use rivet "making system". The model will be avliable soon at VP, content paradise, here at rosity, 3DC, and other fine virtual stores. Even though I'm vacationing, [it's a hard job but some has to do :)]. Keep posting suggestions here, one of the VP team will pick them up and the textures will be made later.
Coming soon to Vanishing Point: a Huey-like Helicopter. We're finishing the textures and finalizing the product name and sales imaes... and it should be ready in the next few days. :)Image rendered in Poser 6 with the base green/ white texture map and rivet bump map.
--John
VanishingPoint... Advanced 3D Modeling Solutions
