Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Lovely scene! I don't have poser 6 either. But I did want to compliment you on the scene. I found sometimes in Poser 5 when I ran out of memory, if I shut down my firewall, closed up my chat programs, and disconnected myself from the net and turned off my virus scanner, I was able to get more memory.
say." - Ghandi
I haven't seen that actual message since Poser 4 - really caught me by surprise. I've since tried to save the figures individualy and I can save the man OK - but get the out of memory issue with the girl. So I'm scratching my head here - Stuck between a rock and a hard place - contiue on with the scene and hope it renders or lose the whole thing - think I will cry.....
The supreme irony of life is that hardly anyone gets out of
it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz 3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
If you've saved the man o.k. you could try deleting him from the scene and seeing if that frees up memory enough to save the rest. If that doesn't work start deleting things like the clothes, hair etc, until you (hopefully) have enough memory to save the important stuff. At worse don't forget to make a pose dot for the female figure. Also you could try and just do a copy paste of her dial settings into a regular old text document. Unzipped
That is RDNA Pre-Raphelite Hair :) This has turned out to be a real pain - ended up taking what I did manage to save into P5 - worked on it there - now to render in P6 .... Grrrr...
it alive.
Robert A. Heinlein
Windows 11 Pro
It seems when the hair was made it wasn't envisaged that the figure would ever be "upside down".
I found that by calculating the frames on the hair with the supplied settings it still sat pretty much in the style it was made with not a real lot of gravity effect. I had to go into the negative settings on the "Pull Down" dial to get it sitting "naturally".
Anway - above is where it is at now - still a lot of tweaking to go - so consider it a WIP. But it should give you an idea of the finished look. The biggest hassle is setting up the animation so as the skirt drapes over the guy's arm and doesn't cross it at any time.
It's certainly teaching me enough about Dynamics :)
it alive.
Robert A. Heinlein
Windows 11 Pro
Actually Unzipped, I'm sorry I didn't start taking screen shots from the beginning with this one as it could turn out to be bit of a tutorial in the long run, as I am really having to think before each step as far as dynamics are concerned. Before this I have only attempted dynamic cloth with one figure and perhaps a prop - never with two figures interacting. In the past I most likely would have dumped the project and moved on to something simplier, but with the couple of positive comments made so far is encouraging me to press on with the project and really see what P6 can do. I must admit too that after coming straight from a First Place in the Best Digital Art Catergory at the recent Denver Starfest sort of adds a little enthusiasm to one's work as well:)
it alive.
Robert A. Heinlein
Windows 11 Pro
Also any feedback / suggestions on lights, backdrop - general will be welcomed....
it alive.
Robert A. Heinlein
Windows 11 Pro
The supreme irony of life is that hardly anyone gets out of it alive.
Robert A. Heinlein
Windows 11 Pro
