Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
they're not quite the best pals you'd expect. Unfortunetly. However you can get positive results if you make sure that you disable the use external binary morph and the use compression options in the misc pref tab in the Poser Preferences. Also, if you use anything like WyrmMaster's Stand-Alone Dynamic Deformers, they will mess up the import of Poser files into Carrara, unless you want to have invisible people :D hth
my assumption is they do not work together. Is this correct?
