Fri, Nov 29, 11:03 PM CST
Subject: transposer 2 and poser 6
neoteric ( ) posted Wed, 18 May 2005 at 3:52 PM ยท edited Tue, 26 November 2024 at 12:22 PM
my assumption is they do not work together. Is this correct?
MrMongo ( ) posted Wed, 18 May 2005 at 4:20 PM
they're not quite the best pals you'd expect. Unfortunetly. However you can get positive results if you make sure that you disable the use external binary morph and the use compression options in the misc pref tab in the Poser Preferences. Also, if you use anything like WyrmMaster's Stand-Alone Dynamic Deformers, they will mess up the import of Poser files into Carrara, unless you want to have invisible people :D hth
Dave ( ) posted Fri, 20 May 2005 at 7:27 AM
Eovia is waiting on a SDK for P6 in order to make importing the new files better. David
