Mon, Feb 17, 11:00 PM CST
Forum Moderators: RedPhantom
Subject: I'd like to hang some posters on my walls
CowboyBozo ( ) posted Tue, 24 May 2005 at 12:50 PM · edited Wed, 25 December 2024 at 7:56 PM
Intuition says the way to do this is by putting a jpg of the poster on a square primitive as a texture and then put the square on the wall... Am I headed in the right direction?
SamTherapy ( ) posted Tue, 24 May 2005 at 12:58 PM
Yep, that's exactly right.
danamongden ( ) posted Tue, 24 May 2005 at 1:05 PM
Watch out for the specular value. Depending on the lights, it's easy to lose some of the image in a highlight. I generally crank that down to 0.1 or so.
momodot ( ) posted Tue, 24 May 2005 at 1:18 PM
If you use the prop box z-scalled down you can magnet some bend to the corners... spheres z-scalled down as thumbtacks.
CowboyBozo ( ) posted Tue, 24 May 2005 at 2:11 PM
Thanks! Looks like I have to adjust the Diffuse value too.
ziggie ( ) posted Tue, 24 May 2005 at 2:31 PM
I have a cheap an nasty poster prop if its any use to you. 30x20 inch put your own pic on... with transparent tape which allows wall color and poster to show through.
"You don't have to be mad to use Poser... but it helps"
SamTherapy ( ) posted Tue, 24 May 2005 at 3:22 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=630435&Start=55&Artist=SamTherapy&ByArtist=Yes
All the artwork on the desk in this pic was done by mapping pictures to the Poser One Sided Square, then adding tape to the edges in (I suspect) the same way as Ziggie. I didn't alter the Specular Value, just the Specular Color to black.
ziggie ( ) posted Tue, 24 May 2005 at 3:41 PM
Doh..! I did mine the hard way and modelled it in Carrara. I knew I dun done summink wrong. I didn't use a Speculum, so I guess its still chrome plated.
garblesnix ( ) posted Tue, 24 May 2005 at 4:02 PM
How is the transparent tape made? This is great, by the way. I'm making something along the same lines myself. Thanks.
ziggie ( ) posted Tue, 24 May 2005 at 4:19 PM
I guess the easy way to make a poster inside Poser is to: 1. Use a one sided square (sized) for poster. 2. Assign a material name to it. 3. Use 4 smaller one sided squares (sized and angled). 4. Position them in the corners and offset them a teensy bit. 5. Assign a material name (the same) to the 4 squares/oblongs. 6. Export as one obj. 7. Import the object. 8. Apply pic to material assigned to poster. 9. Adjust transparacey settings for material assigned to the tape squares.
garblesnix ( ) posted Tue, 24 May 2005 at 4:23 PM
ziggie is great.
SamTherapy ( ) posted Tue, 24 May 2005 at 4:59 PM
"ziggie is great." Yup, the gent certainly is. A genuinely nice guy with a sense of fun.
ziggie ( ) posted Tue, 24 May 2005 at 6:26 PM
*blushes* @ SamTherapy Have knocked up 3 posters. 1. With pins (poster and pins material zones) 2. With tape (poster and tape material zones) 3. With frame (poster, frame and glass material zones) Will zip 'em up and stick 'em in free stuff soonish.
ziggie ( ) posted Tue, 24 May 2005 at 7:12 PM
Attached Link: Free Free... Three Three.... Freethee.... Some Posters..
On their way to Free Stuff or get them at the link above now.
Casette ( ) posted Wed, 25 May 2005 at 5:35 AM
ziggie, nice freeb, thanks for sharing it!!! :)
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
dirk5027 ( ) posted Wed, 25 May 2005 at 6:42 AM
I could use this too, thanks so much
momodot ( ) posted Wed, 25 May 2005 at 8:31 AM
Thank you, Ziggie. And for all your great Freestuff.
Virtua36 ( ) posted Wed, 25 May 2005 at 10:36 AM
Thank you very much.I'm always looking for this little extras that make my scenes complete.:-)
