Forum Moderators: RedPhantom
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=630435&Start=55&Artist=SamTherapy&ByArtist=Yes
All the artwork on the desk in this pic was done by mapping pictures to the Poser One Sided Square, then adding tape to the edges in (I suspect) the same way as Ziggie. I didn't alter the Specular Value, just the Specular Color to black.Coppula eam se non posit acceptera jocularum.
I guess the easy way to make a poster inside Poser is to: 1. Use a one sided square (sized) for poster. 2. Assign a material name to it. 3. Use 4 smaller one sided squares (sized and angled). 4. Position them in the corners and offset them a teensy bit. 5. Assign a material name (the same) to the 4 squares/oblongs. 6. Export as one obj. 7. Import the object. 8. Apply pic to material assigned to poster. 9. Adjust transparacey settings for material assigned to the tape squares.
"You don't have to be mad to use Poser... but it helps"
"ziggie is great." Yup, the gent certainly is. A genuinely nice guy with a sense of fun.
Attached Link: Free Free... Three Three.... Freethee.... Some Posters..
On their way to Free Stuff or get them at the link above now."You don't have to be mad to use Poser... but it helps"
Intuition says the way to do this is by putting a jpg of the poster on a square primitive as a texture and then put the square on the wall... Am I headed in the right direction?
