Mon, Feb 3, 9:59 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Deeper, Baker...
TOXE ( ) posted Fri, 27 May 2005 at 8:57 AM · edited Mon, 03 February 2025 at 9:52 PM
Hi all, i've purchased deeper and baker some days ago. It seems that lately i'm enough stupid or in italy is too hot;-) Example, i've created a sphere, then shading it with a bump channel, baking the bump channel with baker and create a normal map. Import the normal map in the bump channel using deeper or baker. My bump appear exactly as a normal bump. What i have made that don't work?! -TOXE
goofball ( ) posted Fri, 27 May 2005 at 11:22 AM
Baker is helpfull with Anything Grooves objects, create the object and apply an Anything Grooves deformer with the bump that you would like, then try baking it into a normal map.
falconperigot ( ) posted Fri, 27 May 2005 at 11:33 AM
TOXE, you've got to have geometry to bake a normal map. Basically you use a high-res version of your model to produce the normal map, then apply it to and render the low res version.
falconperigot ( ) posted Fri, 27 May 2005 at 11:51 AM · edited Fri, 27 May 2005 at 11:52 AM
Try this:
Place a Sphere in the VM, select all and extrude with unlinked polys, manual offset 1.00. Flip back to the Assembly Room and with the sphere selected bake a normal map, save it, then flip back to the VM. Undo the extrude. Now apply the normal map and render.
Message edited on: 05/27/2005 11:52
