Why are you using texture filtering? This often happens when it's turned on, and the creator of the texture didn't flood-fill the map in flesh tones.
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
You could also try adding a very small amount of displacement to the hair surface in the material room. Sometimes that works for me, depending on the hair.
"you are terrifying
Shire
I reported this error to CL / E-Frontier some weeks ago and they told me that this problem would be fixed with SR 1: >I've done some intensive testing and found that, while the preview issue remains in the LaRoo figure, the render issue has been fixed in the first Poser service release, which is due out shortly. I found this problem occuring on LaRoo, too. That's what this response (from May, 6) refers to. But I have not yet checked it myself if it is really fixed. By the way, I always use texture filtering because it makes much nicer images :-)
It did do it before and it's doing it again and I'd like to be able to use the texture filtering as it does make nicer images, especially the hair. Karen, I did try the displacement and it still doesn't come out as nicely as having texture filtering turned on unfortunately. I guess the other option is to render the character minus the hair without texture filtering turned on and then render the hair seperate but that's not always possible. I'll just have to either muddle thru it or figure out how to fix the character files so the seams don't show.
You may have luck getting comparable results to texture filtering by resizing your hair texture to a smaller size in an image editing program. I assume that the hair texture you're using is comparably large, as in 2000+ pixels wide. Resizing it to something in the 1000 pixels or smaller range could give you results similar to texture filtering without other side effects.
