Mon, Feb 10, 8:43 AM CST
Subject: Necessary Files in Library... Poser 6
DVTVFilm ( ) posted Mon, 30 May 2005 at 11:34 AM · edited Mon, 10 February 2025 at 8:42 AM
My library seems to have several identical files for several items I have acquired. Some say P4, P5 and PP. (thumbnails look identical...) I'm working with Poser 6 (Mac). Can I delete the files that seem to be duplicates of items apparently compatible with older versions of Poser? And, if so, which is the best version to keep for Poser 6?
zulu9812 ( ) posted Mon, 30 May 2005 at 11:48 AM
they are different files, but optimised for different poser versions, e.g. the P5 file takes advantage of features not available in P4 but the P4 files is included for those users without P5.
DVTVFilm ( ) posted Mon, 30 May 2005 at 11:54 AM
So, are you saying keep everything and don't fool around in the folders? Or since I'm using Poser6-- then delete apparent duplicates of item files under Poser-5 level.... since POser 6 would rather use the P5 optimized file over the P4 or PP version...
DVTVFilm ( ) posted Mon, 30 May 2005 at 11:57 AM
I'd love to know the answer to this. I've got the same problem with my Runtime. KRISTTA
Dizzi ( ) posted Mon, 30 May 2005 at 12:13 PM
Usually P6 Files > P5 Files > PP Files > P4 Files.
wheatpenny ( ) posted Mon, 30 May 2005 at 12:27 PM
Site Admin
You can safely delete the p4 and PP ones and just keep the P5 ones.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
DVTVFilm ( ) posted Mon, 30 May 2005 at 12:50 PM
Great---thanks all
Fazzel ( ) posted Mon, 30 May 2005 at 2:13 PM
One of the first things I do when I install something is to delete all the P4 files. They are actually dangerous in Poser 5 and Poser 6 because a lot of them ask for missing .bum files and this can hang your system. Apparently Poser 4 had the ability to create .bum files, but they aren't needed in Poser 5 and Poser 6. PP files are safe to keep and can be used in Poser 5 and Poser 6.
odeathoflife ( ) posted Mon, 30 May 2005 at 4:19 PM
Same, if I get a DAZ item I right offf the bat delete teh p4 folders, if there is no p5 then I keep the PP folders cause they are the most compatible with p5_6
♠Ω Poser eZine Ω♠
♠Ω Poser Free Stuff Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
