Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 12:41 am)
Attached Link: http://www.juno.dti.ne.jp/~yamato-k/Step1.html
Try this, my friend ;)
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
Attached Link: http://www.ebonshire.net/tut-posa/poptop-a1.php
Or this
CASETTE
Could you be more specific in what you need help with? When you install the files, you need to install them in the Runtime folder. The files have paths from the Runtime folder that will install them in the proper places. After that, you need to locate the .pdf file (it will be in RuntimeGeometriesDAZPeople), and run the RTEncoder on it. This will create an .obj file from the .pcf encoded file. Now you can load the Posette/V3 character and use it. If that doesn't answer your question, please let me know what else you need to know and I'll do my best to answer. Thanks, Cres
O.K. , I downloaded RTEncode, opened it, clicked Decode, then what? Clicked File to decode, navigated to Geometries, Daz people, and the box is empty ...doesn't show any files. Its only looking for Rte files and doesn't show anything because there are no Rte files,...It doesn't look for Pcf files. ( I checked and the Hybrid Pcf file IS in Geometries, Daz people.) In the other box, Key file, it's looking for an Obj file. What file am I looking for....V3 or Posette?
You might need MAZ's Objaction Mover, then, not the RTEncoder. Sorry about that. If you go to the Renderosity Free section, go to Poser, then Utilities, then go to the last page and you can find it there. I think .pcf may be Objection Mover instead. The file should be keyed off the V3 figure. Hope this helps, Cres
Each figure has its own copyright and cannot be chopped up and stuck together with other parts from other models. You can chop them up and do whatever you wish with them, so long as you don't redistribute (sell, share, whatever) the results. For your own use (even in a render you intend to use commercially), you can change anything you wish. bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
I really like the anime style heads of Aiko and Hiro, along with the realistic morphs, but I feel their bodies have limited possibilities... Is there anyway to put Aikos head, for example, on She-Freak, or putting Hiros head on The Freak? Ill appreciate any input
