Fri, Jan 31, 2:37 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 12:41 am)
Subject: Aiko's and Hiro's head in other models?
sandmarine ( ) posted Tue, 31 May 2005 at 11:01 AM · edited Fri, 31 January 2025 at 2:35 AM
I really like the anime style heads of Aiko and Hiro, along with the realistic morphs, but I feel their bodies have limited possibilities... Is there anyway to put Aikos head, for example, on She-Freak, or putting Hiros head on The Freak? Ill appreciate any input
timburr ( ) posted Tue, 31 May 2005 at 11:21 AM
There are 2 answers to this. 1) No you can't. Each figure has its own copyright and cannot be chopped up and stuck together with other parts from other models. 2) Just put your 2 models of choice in the same place and make one's head invisible and the others body invisible. Take your choice.
Casette ( ) posted Tue, 31 May 2005 at 11:27 AM
Attached Link: http://www.juno.dti.ne.jp/~yamato-k/Step1.html
Try this, my friend ;)
CASETTE
"Poser isn't a SOFTWARE... it's a RELIGION!"
Casette ( ) posted Tue, 31 May 2005 at 11:28 AM
CASETTE
timburr ( ) posted Tue, 31 May 2005 at 1:27 PM
I checked out the Ebonshire site (above) and downloaded the P4V3 conversion, but there are no instructions or read me. Anyone know how to make these conversions work?
Crescent ( ) posted Tue, 31 May 2005 at 6:51 PM
What P4V3 conversion? What page did you download it from? Thanks, Cres
timburr ( ) posted Wed, 01 June 2005 at 1:38 AM
Click Freebies, then click Contributors 2
Crescent ( ) posted Wed, 01 June 2005 at 11:10 AM
Oh, I'd forgotten about some of the files I'm hosting for others. (I thought I was going senile as I didn't remember making a P4 - V3 figure.) What questions do you have on it? I should be able to help with this. Thanks, Cres
timburr ( ) posted Wed, 01 June 2005 at 2:17 PM
As ststed before, there are no instructions. What do you do with it?
Crescent ( ) posted Wed, 01 June 2005 at 4:19 PM
Could you be more specific in what you need help with? When you install the files, you need to install them in the Runtime folder. The files have paths from the Runtime folder that will install them in the proper places. After that, you need to locate the .pdf file (it will be in RuntimeGeometriesDAZPeople), and run the RTEncoder on it. This will create an .obj file from the .pcf encoded file. Now you can load the Posette/V3 character and use it. If that doesn't answer your question, please let me know what else you need to know and I'll do my best to answer. Thanks, Cres
timburr ( ) posted Wed, 01 June 2005 at 5:39 PM
O.K. , I downloaded RTEncode, opened it, clicked Decode, then what? Clicked File to decode, navigated to Geometries, Daz people, and the box is empty ...doesn't show any files. Its only looking for Rte files and doesn't show anything because there are no Rte files,...It doesn't look for Pcf files. ( I checked and the Hybrid Pcf file IS in Geometries, Daz people.) In the other box, Key file, it's looking for an Obj file. What file am I looking for....V3 or Posette?
Crescent ( ) posted Wed, 01 June 2005 at 6:00 PM
You might need MAZ's Objaction Mover, then, not the RTEncoder. Sorry about that. If you go to the Renderosity Free section, go to Poser, then Utilities, then go to the last page and you can find it there. I think .pcf may be Objection Mover instead. The file should be keyed off the V3 figure. Hope this helps, Cres
timburr ( ) posted Wed, 01 June 2005 at 7:05 PM
Well, we're getting closer.Objaction mover found the pcf file, but when I hit the convert button I get an error message saying "Range check error" .and nothing happens.
Casette ( ) posted Thu, 02 June 2005 at 3:17 AM
(I think its easier to follow the tut ... or at least quicker, as I can see you both) O_o
CASETTE
elizabyte ( ) posted Thu, 02 June 2005 at 3:25 AM
Each figure has its own copyright and cannot be chopped up and stuck together with other parts from other models. You can chop them up and do whatever you wish with them, so long as you don't redistribute (sell, share, whatever) the results. For your own use (even in a render you intend to use commercially), you can change anything you wish. bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
Casette ( ) posted Thu, 02 June 2005 at 3:40 AM
... you can to do any mess with the figures, but they musnt go out of your computer (pics yessss, downloable figures or obj files noooo) I love hybrids
CASETTE
timburr ( ) posted Thu, 02 June 2005 at 11:19 AM
I give up...can't make this work no how no way...delete file!
sandmarine ( ) posted Sun, 05 June 2005 at 6:54 PM
heh, oh well... I think yamato's method is by far the best... the only problem is not having the neck parts for all the needed models... I'll work on it... thanks for the help!
