Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 17 9:52 am)
I have had the same problem with the file dialog being hidden behind the Poser window. One possible work around is to minimize poser using the middle button on the upper left. This will expose the file dialog and allow you to use it. Then just maximize Poser again. This is the only way I have found around the problem and this does not work if you are searching for texture files in the material room. Hope this helps.
Lot's of post about Tiger (Apple OS) and Poser 6
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2284530
http://www.renderosity.com/messages.ez?Form.ShowMessage=2275284
http://www.renderosity.com/messages.ez?Form.ShowMessage=2237958
http://www.renderosity.com/messages.ez?Form.ShowMessage=2206742
http://www.renderosity.com/messages.ez?Form.ShowMessage=2188216
Tnx Carolly 4 ur reply
The problem remain the same. I cannot save my rendered image because the dialogue window remain hidden by poser6. Someone else?!? Using Tiger (10.4.1) sorry (as always) 4 my bad engl. Tnx
