Sun, Nov 24, 1:40 AM CST
Subject: MAC Poser6-SR1.
Luca1 ( ) posted Thu, 02 June 2005 at 6:55 PM ยท edited Wed, 06 November 2024 at 10:43 PM
The problem remain the same. I cannot save my rendered image because the dialogue window remain hidden by poser6. Someone else?!? Using Tiger (10.4.1) sorry (as always) 4 my bad engl. Tnx
oilscum ( ) posted Thu, 02 June 2005 at 8:27 PM
Could you be more specific? Post a screen cap.
hauksdottir ( ) posted Thu, 02 June 2005 at 8:41 PM
Do you have the Dock hidden? What is your monitor's screen resolution set at? What part or window of Poser 6 is covering the dialogue box? Can you move the dialogue box? Carolly
jlarm ( ) posted Fri, 03 June 2005 at 8:38 AM
I have had the same problem with the file dialog being hidden behind the Poser window. One possible work around is to minimize poser using the middle button on the upper left. This will expose the file dialog and allow you to use it. Then just maximize Poser again. This is the only way I have found around the problem and this does not work if you are searching for texture files in the material room. Hope this helps.
Luca1 ( ) posted Fri, 03 June 2005 at 9:00 AM
Tnx for the tip Jlarm the bug appear even using Poser 5 Probably is Tiger not compatible with CuriousLab products...or viceversa?!? waiting for SR2.....
hauksdottir ( ) posted Fri, 03 June 2005 at 2:48 PM
Write to techsupport@curiouslabs.com or find the bug-report form on their site, and let them know specifically what is happening. The more information they have, the more stuff they can fix. Carolly
Luca1 ( ) posted Fri, 03 June 2005 at 3:32 PM
Lot's of post about Tiger (Apple OS) and Poser 6
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2284530
http://www.renderosity.com/messages.ez?Form.ShowMessage=2275284
http://www.renderosity.com/messages.ez?Form.ShowMessage=2237958
http://www.renderosity.com/messages.ez?Form.ShowMessage=2206742
http://www.renderosity.com/messages.ez?Form.ShowMessage=2188216
Tnx Carolly 4 ur reply
