Thu, Nov 28, 7:56 PM CST
Subject: A question about morphs and model cutting to make an open mouth...
rabbit_dawn3d ( ) posted Wed, 01 June 2005 at 1:02 AM · edited Mon, 25 November 2024 at 12:30 AM
Hi, I have a question for anyone who has done modeling. I've seen a lot of models that have been altered to enable them to open their mouths and the original models didn't have an open mouth. My question is how do you cut the mesh to make a mouth? I have a kangaroo model I've been trying to make an open mouth for, and I can't find any answers about how it's done. :( I use Lightwave 7.5, animator, and I also have 3D Studio Max (but I prefer to use LW.). So, if anyone has any answers or can point me in the right direction I'd really appreciate it. :) -Dawn
stonemason ( ) posted Wed, 01 June 2005 at 2:10 AM
I tend to model the mouth open then morph it shut and set the closed mouth as the favoured pose
Cg Society Portfolio
rabbit_dawn3d ( ) posted Wed, 01 June 2005 at 2:17 AM
Thanks. (I'll have to keep that in mind.) LOL! Is it possible to cut polys without cutting the faces all to heck? I've tried slicing in to it a couple times but I get really jagged ugly cuts. :( Thanks for the info, though. Now, I know that it would be easier to make an open mouthed character then a closed mouth one. :) -Dawn
stonemason ( ) posted Wed, 01 June 2005 at 2:22 AM
"Is it possible to cut polys without cutting the faces all to heck? " hmm..not really,if your model doesn't have a mouth to begin with then you'll need to get in & model one yourself..I tend to use symmetry modifiers so I'm only ever modelling one side..that way I can see the inside of the mouth even if the lips are closed. perhaps build the mouth seperately & weld it into the mesh you already have? or post a screenshot of what you have so far Cheers Stefan
EnglishBob ( ) posted Wed, 01 June 2005 at 4:31 AM
Here's how I'd do it in Anim8or. I've started with a simple sphere. The edges marked are where the "mouth" will be.
EnglishBob ( ) posted Wed, 01 June 2005 at 4:32 AM · edited Wed, 01 June 2005 at 4:37 AM
Using the Cut Faces tool, cut across the faces just above the mouth, as close as you can get to the edge. Select "front" so you cut only the faces that are facing your face. :)
Message edited on: 06/01/2005 04:37
EnglishBob ( ) posted Wed, 01 June 2005 at 4:33 AM
...which will give you extra facets like this.
Repeat just below the line, if you want.
EnglishBob ( ) posted Wed, 01 June 2005 at 4:34 AM
Select the extra faces you just made...
EnglishBob ( ) posted Wed, 01 June 2005 at 4:36 AM
...and delete. Make good and tidy up as necessary.
EnglishBob ( ) posted Wed, 01 June 2005 at 4:43 AM · edited Wed, 01 June 2005 at 4:44 AM
Here, I selected the vertices around the "mouth" and applied non-uniform scaling in the Y direction to morph it (almost) closed. I'm sure LightWave can do this somehow, but you said you had Anim8or, and that's what I use... Hope that helped.
Message edited on: 06/01/2005 04:44
oilscum ( ) posted Wed, 01 June 2005 at 10:09 AM · edited Wed, 01 June 2005 at 10:12 AM
Attached Link: http://www.simplylightwave.com/movie_pages/tutorial.mhtml?tut_id=534
Try this tut at SimplyLightwave. Also, the Dan Ablan Lightwave3D books are pretty good.
Message edited on: 06/01/2005 10:12
DominiqueB ( ) posted Wed, 01 June 2005 at 2:45 PM
Select the row of polygons where the upper and lower jaw meets, do a smooth shift pushing the polygons inside the jaw a little, repeat that as many times as necessary to form the throat. Remember to check if the newly created polygons belong to the head body group ( in lightwave you declare them as a "part") before you export to obj other wise the head bone will not move them with the rest of the head. Make all your morphs for open mouth etc... as endomorphs within lightwave and export them.
Dominique Digital Cats Media
stonemason ( ) posted Wed, 01 June 2005 at 8:50 PM
btw,if your animating you may wan't to look into 'edge loops' to get a correct flow of polygons on the face
rabbit_dawn3d ( ) posted Mon, 06 June 2005 at 6:52 PM
Everyone I have to thank you for your advice on everything, but especially EnglishBob! Thank you so much you explained it so simply that even a newbie modeler like me could understand it. You really should copy all that and submit it as a tutorial I looked high and low for something that showed exactly what you did!! Thank you all so very much! Here is the mouth I cut in to the model. Now, I have to model the inner mouth. The model isn't my original mesh but it was a low res one that I thought had a lot of potential. I don't even know where it originally came from now. :( Thank you all very much again!! -Dawn
EnglishBob ( ) posted Tue, 07 June 2005 at 3:31 AM
Thanks Dawn, glad you found it useful. When I saw everyone else chipping in with edge loops and Lightwave stuff, my efforts looked a bit feeble; but it seems I hit the right level, so thanks for replying. This was all fresh in my mind, since I'd recently done exactly the same procedure to cut the front of an open shirt out of a continuous mesh. Anim8or is mentioned in my existing tutorials when a modeller is required, but I deliberately haven't gone into it very deeply, since they weren't meant to be Anim8or specific. I've meant to do one for some time, which probably means I'll never get around to it. :)
