Did you flatten the cube? Try using the one sided square instead, that sometimes helps with these artifacts. I am not 100% sure why it happens, I had it happen recently with the Daz freebie temple as well... You're using P6, right?
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1957629
Used to have the problem. Dunno if this will help. :-)Hmm. Looks like a pretty nice "sci-fi" background to me (now, which button should I push? This one? Or that one? No - wait - that button looks good...) Pity you couldn't reproduce the effect, it could have come in useful:-)) OTOH, I'm glad for you that the problem went away; unwanted side-effects are always a PITA.. Cheers, Diolma
A footnote : it has occurred to me that when I got the problematic pattern on the prop, I had bumped up the atmospheric strength on the spotlight, and also set the atmosphere dial to about 0.01 to create a volumetric fog effect. I wonder if that had anything to do with it ? (I should have mentioned this at the beginning)
Still.. I got the same effect on a Daz prop.. you can see it clearly in the pic HERE - in the background. So how do you fix THAT? I can't just swap the temple for a ine sided square L Or would it help with the thing Stewer mentioned? the Normals forward? Unfortunately I didn't save the PZ3 so I can't try it :) Is it an error in Poser or an error on certain props? As it doesn't do like this on ALL props... And if it's an error in the prop, what can be done to eliminate it? (I wouldn't like to make a prop that had this error)
![file_252138.jpg](https://live.cdn.renderosity.com/forum/threads/2291540/file_252138.jpg)
Hi all, I set up this image with the background being the Prop square translated in the negative z-direction to be behind the subject, and then scaled to 2000% so that the background would fill the entire portrait. When I rendered it, I got the weird pattern on the background. I had not applied any material settings apart from the plain vanilla white setting that comes with the square prop. Can someone please tell me what is going on here, and how I can fix this problem ? thanks and regards, Andrew
