Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 09 12:13 pm)
Did you try Menu>Render>Reload Textures ? I was making changes to a tex the other day (and re-saving as the same filename) and each time I hit "reload textures" I could see as my tex updated in the preview. It seems to override "Keep textures loaded", forcing a reload anyway, but maybe it's better to have "keep textures loaded" un-checked while working on the texture.
I am having trouble updating textures when I alter them. For instance, I may be working in Poser 6 and have applied a texture to an object, but then I want to alter the texture in a graphics program. But if I do this, Poser 6 does not update the texture. I tried changing textures and then changing again, back to the original, but the changes still did not update. The only thing I can find to do is close Poser and re-open -- then the texture changes are updated -- but this very tedious if I want to experiment with textures. Is there some function in Poser that I am not aware of that can help me? Thanks.
