Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 10:21 pm)
Try posing your figure first. When you are satisfied with the pose...add the conforming clothing. With adding new clothing...well..the textures go in your texture file under poser....the others should go into library..under charactors...clothing..The cr2 and rsr files. You might want to put a name there like "my clothes" or something.
I too appreciate the above tips. Am I correct in assuming that, in order to animate a figure with comformable clothing, that one would have to adjust the clothing in almost every key frame to keep the figure from busting through the clothes in places?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
Well, the PRIMARY figure can be taken care of via HIDING the body parts that are supposed to be FULLY covered in clothing. If it's a PARTIAL covering by clothing, then a transperancy map on the primary figure in that area might work. Seems that would be a lot of trouble. I am still experimenting around with the posable SITTING dress situation :o) If I come up with a solution, it'll be posted in a new thread here.
Attached Link: http://hispraise.com/TOLife/gallery.htm
Thanks a lot, Warrior! I will definitely keep checking this newsgroup. I have had Poser for about 10 months now, but haven't REALLY spent time learning it. Mostly do what I need to do in it and then export it into a wavefront obj to use in Bryce...This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Attached Link: Tree of Life Gallery
Hi, how do I make clothes "pose" with the body? I have used the "conform to" command and that's fine, but if I apply certain poses to the figure, the clothes don't pose with them... I also don't understand how to see some of the new clothes I recently added. I thought I followed instructions as to what directory to unzip the files to, but I still don't see them in the library.
