Sat, Sep 21, 7:36 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 1:47 am)
Subject: conforming clothes to figures
newwine ( ) posted Sat, 10 February 2001 at 6:35 PM ยท edited Fri, 19 July 2024 at 3:43 AM
Attached Link: Tree of Life Gallery
Hi, how do I make clothes "pose" with the body? I have used the "conform to" command and that's fine, but if I apply certain poses to the figure, the clothes don't pose with them... I also don't understand how to see some of the new clothes I recently added. I thought I followed instructions as to what directory to unzip the files to, but I still don't see them in the library.
Poppi ( ) posted Sat, 10 February 2001 at 8:38 PM
Try posing your figure first. When you are satisfied with the pose...add the conforming clothing. With adding new clothing...well..the textures go in your texture file under poser....the others should go into library..under charactors...clothing..The cr2 and rsr files. You might want to put a name there like "my clothes" or something.
WarriorDL ( ) posted Sat, 10 February 2001 at 11:59 PM
Always make sure you are posing your PRIMARY figure that the clothes are conformed to. Also, if you are trying to pose a figure with a long dress into a siting position- Forget it unless you're real good with magnets and/or making morphs.
newwine ( ) posted Sun, 11 February 2001 at 12:36 AM
Hi, Thanks you guys... That's what I was wondering.. I am trying to pose this girl in a sitting/kneeling position.. LOL it ain't working! I guess I gotta go back to the drawing board..
Terry Mitchell ( ) posted Sun, 11 February 2001 at 7:59 AM
I too appreciate the above tips. Am I correct in assuming that, in order to animate a figure with comformable clothing, that one would have to adjust the clothing in almost every key frame to keep the figure from busting through the clothes in places?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
newwine ( ) posted Sun, 11 February 2001 at 12:38 PM
Sounds like it. that sucks...
WarriorDL ( ) posted Sun, 11 February 2001 at 1:32 PM
Well, the PRIMARY figure can be taken care of via HIDING the body parts that are supposed to be FULLY covered in clothing. If it's a PARTIAL covering by clothing, then a transperancy map on the primary figure in that area might work. Seems that would be a lot of trouble. I am still experimenting around with the posable SITTING dress situation :o) If I come up with a solution, it'll be posted in a new thread here.
newwine ( ) posted Sun, 11 February 2001 at 2:13 PM
Attached Link: http://hispraise.com/TOLife/gallery.htm
Thanks a lot, Warrior! I will definitely keep checking this newsgroup. I have had Poser for about 10 months now, but haven't REALLY spent time learning it. Mostly do what I need to do in it and then export it into a wavefront obj to use in Bryce...
