Thanx for the kind words Hawkfyr,thought long and hard about my setting before I started as I figured the standard was so high I needed to do something original to try an stand out from the crowd:) might try that patch render option you mentioned in an earlier post to dull the sun (never even new it existed,thanx)as I dont fancy a full re-render,have a 1000 thunderbird an it still took 4 hours!
Hi Ironbrew, You might wanna re think the patch renger when it come to lighting, after all , the sun is creating light in your environment, if you dim it and then do a patch , there will be a very noticable contrast between the existing sun and the patched area, The patch render is nice for changing elements that dont really effect the overall look of the image ( such as light) but it's great for re sizing and eliment, modifying a material or eliminating a bothersome eliment in your scene. Just wanted to give you the heads up on that so you can be prepared for that. you can always do a test to see though. The bubbles are a nice touch in this scene. very well done image Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
Thanx jade:)I achieved the look by making a large cube and giving it a water texture,all the underwater objects are actually placed inside this cube including the camera as this is how it actually is in real life,never used a water plane at all.Think ill just leave it as it is then Hawk as getting the lighting right was the hardest part of the picture,actually needed four lights in the scene to get it right so better not muck around with them hehe.
I had the same problems JVogel when I tried to use volume slabs for my water - everything was just too darn dark. I think the key is what ironbrew said you have to add lots of dim lights to bring out the detail of the objects but not too bright so that you still get that murky water effect. I ended up just using a water plane and playing with the sky. Someday I'll learn how to light things better and maybe I'll like using those volume slabs for water. Jade
