Wed, Dec 25, 9:52 PM CST
Subject: Lightwave Terrain Export
tony3d ( ) posted Sat, 18 June 2005 at 1:51 PM · edited Wed, 25 December 2024 at 9:17 PM
Hi, I just got Vue 5 Infinite and found that the terrain export for Lightwave only exports the bump map even though I select the color maps also. When will this be fixed as that was one of my main reasons for spending $600.00. It seems to export plants fine. I really need this feature to work. I have the latest patch installed. 5.07XXX. Please help.
krimpr ( ) posted Sat, 18 June 2005 at 2:22 PM
I seem to recall having problems with this as well. Try reducing the resolution of your color map export. (Can't recall if that solved it for me or not, but for some reason I think it did.) It's worth a shot...
videodv ( ) posted Sat, 18 June 2005 at 2:34 PM
Just tried it here from the file menu and its working as it should. If you use the export from the terian editor then I found it puts the bump map in the colour channel (in cinema) I just had to reselect the colour map and it worked ok. Will have to put this over to tec support. videodv.
tony3d ( ) posted Sat, 18 June 2005 at 4:46 PM
The Lightwave export doesn't even create the color map!
videodv ( ) posted Sat, 18 June 2005 at 5:31 PM
In my tests I used the sandstone mat and I got the terrain.lwo file plus three texture maps one called terrain (terrain bump?) the second was the bump map for the sandstone mat and the third was the sandstone colour map. See attachment. videodv.
videodv ( ) posted Sat, 18 June 2005 at 5:51 PM · edited Sat, 18 June 2005 at 5:52 PM
I have just done a few more tests and let me say sorry about the above post it seems I forgot to delete the maps between test and you are right, if you use the export from the terrain editor it will not export the colour map.
But if you hightlight the terrain and use the export object from the file menu it works as it should, and produces the colour and bump maps.
Sorry again for my mixup.
videodv.
Message edited on: 06/18/2005 17:52
Rids ( ) posted Sat, 18 June 2005 at 6:16 PM
As videodv says above, if you highlight the terrain and then select export object from the menu then it works perfectly. Here's a very quick one from VI to LW8.3:
tony3d ( ) posted Sat, 18 June 2005 at 7:06 PM
Thanks Guy's I'll try that as soon as I finish this Lightwave job.
