I have just done a few more tests and let me say sorry about the above post it seems I forgot to delete the maps between test and you are right, if you use the export from the terrain editor it will not export the colour map.
But if you hightlight the terrain and use the export object from the file menu it works as it should, and produces the colour and bump maps.
Sorry again for my mixup.
videodv.
Message edited on: 06/18/2005 17:52
Hi, I just got Vue 5 Infinite and found that the terrain export for Lightwave only exports the bump map even though I select the color maps also. When will this be fixed as that was one of my main reasons for spending $600.00. It seems to export plants fine. I really need this feature to work. I have the latest patch installed. 5.07XXX. Please help.
