Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 27 1:11 pm)
Attached Link: http://www.curiouslabs.com
Use the Group tool (box just to the left of the Bone tool) to create groups of polygons associated with bones. The Setup Room does not require you to import OBJs with layers/split parts. Please refer to the Setup Room chapter in the Pro Pack User Guide. It explains how to set up the figure in great detail. I know- I wrote it! :-) Anthony Hernandez Senior Techincal Writer Curious LabsIf it has 4 limbs and wings, try loading the dog or horse skeleton and positioning the bones to fit your model. You can then select a parent bone (chest or abdomen, probably) and add bones to the wings. Draw bones on both sides, position bones on one side of the figure and use symmetry to apply the settings to the other side. Saves time and ensures that both sides of your model behave the same. You may need to specify rotation orders, falloff, zones, etc. to get it exactly right, but the Setup Room will save you a lot if time over having to do everything manually. Anthony
Anthony's work is an example of what happens when you hire a fan to work with you. They just keep going and going and going. In the words of Nance "Well done Anthony!" Steve Cooper Curious LabsThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi. I'm getting ready to make this little guy I have poseable. I have Pro Pack so it's supposed to be pretty easy. I used Rhino to model the guy. Ok, I split the body parts and set them in separate layers in rhino like you're supposed to do. I then exported them all as an OBJ. I take it into Poser Pro and create the bones perfectly. What do I do after that? I tried everything but can figure out for the life of me what to do. Please help or point me to some Pro Pack tutorials? Thanks :)
