Mon, Dec 23, 7:59 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Noise
Radlafx ( ) posted Mon, 27 June 2005 at 1:46 PM · edited Tue, 26 November 2024 at 10:26 AM
What is the best way to get noise out of pictures.
Question the question. Answer the question. Question the answer...
I wish I knew what I was gonna say :oP
3DGuy ( ) posted Mon, 27 June 2005 at 3:24 PM
Use a lower iso setting
What is a friend? A single soul dwelling in two bodies. - Aristotle
-= Glass Eye Photography =- -= My Rendo Gallery =-
TwoPynts ( ) posted Mon, 27 June 2005 at 3:31 PM
Which means less noise to begin with. It is very hard to get it out of an image once it is in. One way is to reduce the image size so that it isn't so noticable. The other way is to use aftermarket filters like Neat Image so remove it. The only problem with that is when you remove the noise, some of the image detail usually goes with it. These filters are getting better at it all the time, but still it is better to minimize it in the first place. Also, try keep your photo exposure in the sweet spot (using your in-camera histogram as a guide). Excessively shadowy images get noisier when you adjust the level to compensate.
tibet2004uk ( ) posted Mon, 27 June 2005 at 3:42 PM
Nothing to add here! they said it all! yep! :)
3DGuy ( ) posted Mon, 27 June 2005 at 4:36 PM
I've been a bit short.. so in addition: check out noiseninja http://www.picturecode.com/ or helicon filters: http://www.heliconfilter.com/pages/
DHolman ( ) posted Mon, 27 June 2005 at 8:22 PM
Helicon Filter is an excellent program. One of the best noise removal algorithms around too. Also check out Kodak's Digital Gem and Digital Gem Professional (use to be ASF's program). Info is HERE. -=>Donald
Radlafx ( ) posted Mon, 27 June 2005 at 10:40 PM
Thank guys thing is I'm Shooting baseball at night so I gotta use a high iso.
TwoPynts ( ) posted Tue, 28 June 2005 at 8:35 AM
Ahhh, so you will be getting noise no matter what. Well then, any of the recommended removal filter should help. Some other postwork tips might be to blur backgrounds and dark areas to fade the noise, and to increase the contrast so that a noisy dark background become black. What camera are you using? Good luck!
Radlafx ( ) posted Tue, 28 June 2005 at 5:24 PM · edited Tue, 28 June 2005 at 5:25 PM
Thanks I'm using a dimage Z5.
Message edited on: 06/28/2005 17:25
TobinLam ( ) posted Tue, 02 August 2005 at 12:56 PM
That is a sweet picture! I love the pitcher's tongue sticking out! I can definitely see some noise.
