Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 11 2:56 am)
I was having the same problem. I finally just caved and decided to reformat my computer. Poser has been doing weird things on me lately. One day the INJ worked, then a few days later they didn't. I reinsalled the base figure and the head and body morphs, and then some INJ worked, and some didn't. Figured it was less headache to just reformat and reinstall everything than to figure out what Poser was up to.
say." - Ghandi
Thanks to all for the suggestions. I've found a workable solution, without reformatting my hard drive. To Acadia: OUCH! First, I created a second user on my computer, called Poser User, that I log in as whenever I want to use Poser. Second, I set McAffee Virus Scan to "disable" at boot up, so it doesn't take up memory. I launch Poser, which takes about a minute to boot. Then I exit Poser and launch it again. This time, Poser starts in about 15 seconds, because all the TSRs are in memory. Voila! No more loading problems. A bit of an inconvenience, I know, but one that I can live with. Hope this helps others as well.
I'm having the same problem with the injects in p6. I used the morph/injects in p5 fine, but just started trying to use the mil figures in p6. With the Mil Figures I did a new install into the P6 folder. I created a seperate subfolder called v3m3 and did the re-install - thank god DAZ lets you reset downloads! After the m3 injects started hanging up, I thought there might be a problem with p5 still be installed, so I uninstalled it. Still no joy. So I uninstalled and reinsalled all the m3 content. But people are finding that they MUST go into the main runtime, is that correct? That sucks.
Hi folks. I've been having a problem for a while with INJ morphs for the millenium figures. More often than not when I try to INJ all morphs, or even certain families, Poser 5 just hangs. I get the hour glass but nothing seems to happen, and I am waiting several minutes. Any idea as to what could be causing this? I"m running XP Service Pak 2, Poser 5.04.332, 1 gig of RAM, and all Virus checkers have been turned off. Any advice would be appreciated; thanks!
