Blender F.A.Q (Last Updated: 2025 Feb 02 8:19 pm)
to round them use the subdivide option and set it higher then 0
for
some free stuff i made
and
for almost daily fotos
that's subdivide smooth, not just subdivide :) You may also want to use the tools in the knife tool menu (k key) and reposition the new vertices manually. It's strange that your poser figures won't import, it'll be really obnoxious getting stuff to fit unless you can get that to work. I wish I could help, but I don't have poser or V3 and M3. Other people have posted and solved different import problems, I don't know about yours though.
Oh yeah, you'll probably also want to work with one side mirroring the other so it's less fuss to keep it symmetrical. To do that:
to make it into one object again,
Message edited on: 07/05/2005 22:22
If you have a low end system (like I do) it can take a long time for Poser figs to load because of there high polygon count. Then when they do load you may not have enough system resources to do anything with them. A so-so work around is to make images of your Poser figs (sides, front, top, back, and bottom) and use these as references in Blender (ViewBackground Images).
