Fri, Feb 7, 6:30 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Wardrobe Wizard and Smaller Figures
egaeus ( ) posted Wed, 06 July 2005 at 12:14 PM ยท edited Fri, 31 January 2025 at 3:10 AM
I have both Wardrobe Wizard and Clothes Converter, and I have been having trouble with the same issue with both of them. I am addressing WW here because it seems to be the easier of the two programs to use.
I can not seem to get larger clothes (i.e. Vicki 3, Michael) to scale down suitably to smaller figures like the Millenium Girls. The size difference seems to be so great that the reduction of the clothes almost utterly destroys the clothing. No amount of smoothing, inflating, deflating seems to work. The best I can usually get is some ragged version of the original model. I've gotten a couple of very simple clothes objects to come out all right (a wrap-around towel), but anything more complicated doesn't work well. I even tried scaling the Millenium Preteen up to a larger size, but got similar results.
Any suggestions/hints/tricks?
Mike
Message edited on: 07/06/2005 12:15
ziggie ( ) posted Wed, 06 July 2005 at 12:27 PM
I have used WW to scale adult clothing down to the Mil kids without too much of a problem. Is seems to be better within the groups of figures pre unimesh and unimesh. Changing between the two groups doesn't seem to be so easy... I think because they have differently styled body parts/joints.
"You don't have to be mad to use Poser... but it helps"
JohnRickardJR ( ) posted Wed, 06 July 2005 at 12:29 PM
I've had no problems going from S3P to Laura, so the size issue might not be the problem.
HAWK999 ( ) posted Wed, 06 July 2005 at 12:54 PM
I believe the trick is to scale the smaller figure roughly to the size of the clothing, do the conversion and rescale the figure to 100%
SAMS3D ( ) posted Wed, 06 July 2005 at 3:49 PM
I had this problem and Phil told me I must have to smooth all quite a few times, which I tried on one object and it worked, the other one did not and I think that had to do with the above with the mesh and unimesh...unknown though. But the item I did, I smoothed 17 times and then inflated it once and it worked great. Sharen
BastBlack ( ) posted Wed, 06 July 2005 at 8:15 PM
On the yahoo group, there's a tutorial for scaling Laura up to V3's size, doing the conversion, then scaling Laura and the converted clothes down. Some people swear by this method. bB
egaeus ( ) posted Thu, 07 July 2005 at 2:56 PM
Here's another question, then -- converting clothes for TenTen to Laura. For some reason, I can't make TenTen's breasts in the clothing go away. Mike
BastBlack ( ) posted Thu, 07 July 2005 at 3:25 PM
I tried to convert TenTen Mill Girl Miko outfit and the ISOP Kimono for Posette and also had this problem. For the ISOP, I created a new OBJ of kimono top to get around it, but surely there is a better way. bB
HandyGM ( ) posted Sun, 17 July 2005 at 9:32 AM
The latest SR fixes the 'smaller figure' problem. Try it now, see if you still have probs.
