Wed, Feb 12, 9:05 AM CST
Subject: warped sides of props in P6?
Felsir ( ) posted Mon, 11 July 2005 at 2:10 AM ยท edited Wed, 12 February 2025 at 9:02 AM
Hi, I created a 3DS object (an arcade cabinet) and imported it in Poser 6. It looks okay in the poser view but when rendered sides appear curved leaving gaps where sides should match. I thought that I made a mistake in 3DS but then I noticed the very same warp effect in a test render I made with the "eggshell chair" that came with Poser 6. The "feet" of the chair has straight sides with a slight bend on the end, Poser renders this as one curve leaving huge gaps where the sides should line up. Anyone else noticed this? Is it me or is it a bug in Poser or the props? I checked some of the objects I bought (DM Timeprisoners) and so far those objects seem okay - however they don't have the kind of sides like the chair or my arcade cabinet have (sides that start straight and bend on the end). Any ideas? -Felsir
Tashar59 ( ) posted Mon, 11 July 2005 at 2:21 AM
Attached Link: http://www.UVMapper.com
Go into properties and uncheck (Smooth polygons.) you can also split vertices in UVMapper Clasic which is Free.
Felsir ( ) posted Mon, 11 July 2005 at 2:27 AM
Thanks, going to try that :-)
LostinSpaceman ( ) posted Mon, 11 July 2005 at 2:29 AM
Can you post an example image?
Felsir ( ) posted Mon, 11 July 2005 at 2:33 AM
@Mizrael: yes, I will post a sample later today (I'm at work now so I don't have my home PC near).
stewer ( ) posted Mon, 11 July 2005 at 2:54 AM
In Poser 6, you can try reducing the crease angle of the object.
Fazzel ( ) posted Mon, 11 July 2005 at 10:06 AM
Is it me or is it a bug in Poser or the props? It isn't a bug in Poser or the props. It is doing exactly what you tell it to do if you have smooth polyons checked on in your render settings.
Felsir ( ) posted Mon, 11 July 2005 at 11:51 AM
I will check out the settings in the UVMapper tool to see if I can get it to work. I attached a file with the render of the "eggshell" chair, to illustrate the effect I'm talking about.
