Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Have you tried substituting a different model at that frame with a different behavior? Or is that not possible? Or is it possible to assign a model a new behavior at a new frame?
Is the movement similar to that wormhole generator in the movie Contact? Where you have the rotation of one object's spinning axis influenced by the ratation of another object's spinning axis?
Message edited on: 07/12/2005 02:47
Hi TOXE, I'm glad you are saved from the balcony. :) I hadn't used this method before - just thought it might work. And after posting I thought it should work for any groups but couldn't try it becuse the electricity has been off all morning. :( Now I'm going to look at your files. Thanks for posting. Cheers, Mark
I use multiple behaviors stacked/applied to groups all the time. It's especially useful for coordinate transformations as well. For example, if you want to make a fan with a bunch blades all canted at a specific angle, you can; 1.) Make the blade. 2.) Orient it at the canted angle. 3.) Group it which resets the coordinates with a frame of reference with no rotation. 4.) Move the hotpoint to the base of the fan blade. 5.) Rotate the fan blade the number of degrees equal to 360 divided by the number of fan blades. 6.) Duplicate until you have what you want. Grouping and modifying can save LOTS of time! -Kix
-Kix
Attached Link: http://www.dexfx.com/Effects.htm
I've also used the grouping behaviors before -- my flying saucers attacking San Francisco (see the link) have some side to side motion (yaw, I guess). Then, I group the flying saucer, move its hotpoint WAY off center of the object, then rotate the group to get the nice circular flight path. Very useful technique that I think I read about first here in 'rosity way back when Clint was the RDS moderator. - DexAttached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1534889
Remember this? http://www.renderosity.com/messages.ez?Form.ShowMessage=1534889Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1095787
Really nice and useful Nicholas! Now i remember:-) Someone remember also this? -TOXE
Hi all my friendssss, someone know if there is a way to convert behaviors in frames?! If not, i'll jump from the balcony (i'm on the first floor, nothing serious) -TOXE
