Forum Moderators: RedPhantom
Mac, do you have the memory update installed? I seem to remember something about this problem happening if P4 was installed on a machine with more than 1GB total RAM.
Deecey, Absolutely. I got them yesterday. SamT, Hmmm... I have 2 gigs of RAM. I never thought on that. I've just looked through my backup drive and can't find it. I was sure I had it at one point. OK. I'm off to CL. If that's the answer, I'll worship you as a God among men.... well, a jolly good chap anyway... mac
Well, I had to register at CL yet again. That makes it 3 times I've registered now. And when I got to the page, I got this. Warning: filesize(): Stat failed for /data/httpd/www.e-frontier.com/ezfilemanager/files/phpLPcoMJ (errno=2 - No such file or directory) in /data/httpd/www.e-frontier.com/ezfilemanager/user/filedownload.php on line 188 Damn! After 2 days of faffing around, I'm pipped at the post. The whole CL site seems to be FUBAR. No images at all. I thought it was because I had animations turned off, but maybe the site's up the spout. Oh well, I suppose I could even get some sleep. That's a novel idea. Altogether now : 'Yes, I got it from a novel!' Argh! Thanks all. mac
Mac - the site is working perfectly ok for me. Try it now, if you're still around. Obviously, if you're not, you can't. :)
What is it about P4 that you still want to use? Are there old Python Scripts that won't run on P6? Now that I've been running P6 for a while, I am considering uninstalling P4 with PP completely and just moving the runtime library so as not to have to install all my stuff again. Poser 6 definitely has a better rendering engine. The only thing that is stopping me is that Vue 5 don't like P6 figures or files yet, I've been having import issues, but once that is resolved I may reconsider if I still need the older version.
Ok, here's something weird - I had also got a new pc around Christmas time with 2GB RAM but Poser 4 is running smoothly on it. Well, I don't use it all that often since getting P6 but I've never had this happen. Or could it be that I've installed a newer Curious Labs version of Poser 4 that we got ever since giving our old Metacreations version to my niece?
hi all, I finally got the updater and P4's up and running. Thanks for the help. I never even thought on the 1 gig limit, since my old machine only had 512Mb. Tomsde, Yep, I'm a merchant and need P4 for testing/compatibility. I do all assembly in P4, then move to P6 for final saves and shader work. Now to try and get some work done. mac
One of the reasons I assemble in poser 4 is that if my stuff looks good in it, it'll look even better in P6. I'm a great believer in starting from the bottom up. I make each product in 2 versions - poser and daz studio. The poser version will work 100% in P4/5/6 and if I add any shaders, I also include a P4 texture which is similar. That way everybody's happy. And there are still a lot of P4 users out there. It's a bit more work, but I build products for long-term sales, not quick, trendy things for whatever happens to be the figure of the moment, so I prefer to make them solid before they leave my computer. cheers mac
Hiya mac...
Sounds like you got it sorted out, but in case it flairs up again I wanted to let you know I had EXACTLY the same problem when I got a new machine last month.
I solved it by decreasing the lower bound limit for the swap file size (a solution I found from somewhere I don't recall... maybe here on Renderosity after doing a forum search...??).
Good luck with the new machine, and I hope all's well with you.
Tguy
I just got a new machine, as followsP4 3.2 / Nvidia Geforce 660GT / 2GB RAM / SATA master + IDE slave / running win 2k
So, yesterday I did a clean install of everything, including P4 and P6. P6 is fine, but P4 is giving me invisible figures. Everything's invisible, from figures to props.
So I re-installed the system and did it all again. This time I noticed that after installng win 2k + SP-1, poser 4 was OK. When I installed SP-4, it went crazy. So I went to MS and got all the latest patches. Nada. And on my old machine, I have the exact same OS/SRs, and P4's fine.
I've also tried removing and re-installing P4. It's the latest, complete with 4.03 patch. I have it on a separate partition from the OS, with P6 on another partition. P6 is fine -100%. All other apps - photoshop, 3d max, daz studio are fine. So before I start a long drawn-out correspondence with CL, if anyone has a great idea, I'm listening.
TIA
mac PS The pic shows what I got right after install. All I did was move the cams/lights out the way and drag the doc window to a larger size. As you can see, even that didn't work too well. The default guy is there, but I only see the outline by running the mouse over him.
Message edited on: 07/16/2005 17:49
