Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
No, I don't. I only have that for Poser 6. Poser 5 is not even showing in the Start Menu anymore. If I want to run Poser 5, I have to go to its folder and double-click on Poser.exe. I had a link in my Quick Launch bar for Poser 5 but now if I use it, it launches Poser 6 instead. And Poser 6 is not installed in the same folder as Poser 5. I have both of them outside of Program Files. France
France, Proud Owner of
KCTC Freebies
Oops, I didn't see your reply wyrwulf. So then it is really okay to just remove Poser 5 folder?
KCTC Freebies
Thank you all of you. I made sure to retrieve all I could need from that folder. Now I will remove it and make some room for Poser stuff. ;o) Of course I could always re-install Poser 5 if I ever want to as I have the CD for both P5 and P6 but it is useless on my computer now. I much prefer Poser 6!
KCTC Freebies
Nah... It unnerves me to play with Regedit ;o) I deleted Poser 5 folder and I guess it will have to do. Thanks!
KCTC Freebies
Attached Link: http://www.sofotex.com/downloads/d7528.html
France, I don't like to manually tinker with regedit either. So I found this really great program that does it for you. I use it alot! :) Automatically finds reg problems and then you can delete them safely. http://www.sofotex.com/downloads/d7528.htmlI installed and ran it last night... Found 98 errors and fixed them! Thanks a lot!
KCTC Freebies
Since I didn't use Poser 5 since I have Poser 6, I would like to uninstall it. I go to Add/Remove Programs and it doesn't show up in the list! Looked into Start Menu/All Programs and it's not there either. How can I uninstall it without uninstalling Poser 6? Thanks. France
KCTC Freebies
