Mon, Dec 2, 2:10 PM CST
Subject: Struggling with Sketch setting:
mikecoulter ( ) posted Mon, 25 July 2005 at 12:40 PM · edited Mon, 02 December 2024 at 11:48 AM
I am trying to output a particular Sketch render but failing miserably.
What I am trying to achieve is an output of a character where there is a complete outline, and complete black lines for the object's jawline, eyes mouth etc.
I've tried different sketch perameters in the Sketch Designer window, such as turning off hatching in 'objects' and lengthening stroke and density in 'Edges' but the best I come up with is the example here.
Is it possible to get clean lines for the complete outlines and for facial features?
Cheers MIke.
vilian ( ) posted Mon, 25 July 2005 at 6:27 PM
Dr Geep made a tut about Sketch Designer, explaining which setting does what. I don't think you can go any better with it, but maybe try to use some pre-defined presets ? Over at Animotions' Freestuff there's a nice pack of Sketch Designer presets. I had very little luck myself with that thing. I got one pic at my gallery as an experiment, but I guess it was a failure. Interesting, yes, but not as good as I hoped.
Outdated gallery over at DeviantArt
Fics at FanFiction.net and Archive of Our Own (AO3)
SWAMP ( ) posted Tue, 26 July 2005 at 12:31 AM
It's the lights you need to play with. Use a simple two or three light setup. The dark areas are what show the sketching the most, while bright areas show the least. This is the default sketch preset, with two dim lights on each side and one bright light directly in front (and on) the face.
SWAMP ( ) posted Tue, 26 July 2005 at 12:33 AM
Same setup except the one bright light raised up above the head to cast shadows on the face. See how the light(s)/shadows play an important role in what does and does not get sketch. Note: Sketch Designer doesnt work at all well with transparency maps. For the eyelashes I changed the object color to white as a work-around. For hair it is best to use the old crappy (non-trans mapped) plastic hair that comes with Poser for the same reason. The eyes will render better if you set the eye white object color to dark gray and the irises object color to black (as I did here). Hope that helps.have fun, SWAMP
elizabyte ( ) posted Tue, 26 July 2005 at 12:36 AM
Another thing I've found useful/helpful is to render the image first, and then import it to the work area as a background, deleting or making invisible all figures in the foreground, and running the sketch designer on that. I've gotten some really interesting effects that way. bonni
"When a man gives his opinion, he's a man. When a woman gives her opinion, she's a bitch." - Bette Davis
mikecoulter ( ) posted Tue, 26 July 2005 at 12:49 AM
Thanks ever so much for the input folks, excellent advice. I feel I'm really getting somewhere. much appreciated/ ;-) Mike.
