Mon, Dec 2, 6:47 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: how the heck do you use cloud planes?
JoeBlack ( ) posted Tue, 26 July 2005 at 6:20 PM ยท edited Mon, 02 December 2024 at 6:38 AM
I'm trying to figure out a way of creating a certain scene, and one way was to use cloud planes. But I cannot for the life of me work out how you use them - the stupid manual seems to say nothing about them (though I only read the online manual).
I created a plane, and applied a volumetric cloud to it...and this is the bizarre result. WTF? No matter how I try to modify the plane material, it just seems to go beserk.
JoeBlack
nanotyrannus ( ) posted Tue, 26 July 2005 at 7:40 PM
Looks like either the scale or the mapping, try changing the scale and also try changing the mapping mode to object: Parametric and see if that does anything, I've never seen anything like this myself except when using images before changing the mapping mode. Hope this helps!
lingrif ( ) posted Wed, 27 July 2005 at 4:27 AM
Are you using alpha planes? That's the only way I know how to get them to work.
www.lingriffin.com
Doofus ( ) posted Thu, 28 July 2005 at 10:02 PM
I just did a quick check with vue 4 and what I found was Vlumetric clouds gave Me the same type results as the above pic. If I used any of the other cloud types and not a volumetric for the cloud plane they looked just fine. Give it a shot.
mamba-negra ( ) posted Sun, 31 July 2005 at 10:13 AM
Is your atmosphere volumetric?
