Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
why dont you set the walk cycle to repeat twice and just use the first walk cycle? this sometimes helps or copy the first frame to the 16th frame and adjust the 15th so that runs smoother to the 16th, then delete the 16th...
Getting old and still making "art" without soiling myself, now that's success.
![file_279771.gif](https://live.cdn.renderosity.com/forum/_legacy/file_279771.gif)
I made a 15-frame run animation using the P6 walk designer. Run, Shuffle and Sneak were all set to 60%, with the character walking In Place. There is a slight delay between the 15th and 1st frame, which results in the transition being jerky. Obviously, some tweening will sort this but that kind of defeats the purpose of computer animation. I've also noticed that the Walk Designer always does this. Is there anything I can do to make the walk designer work better?
