Procedural in this case means the actual resolution is calculated in relation to the distance to the camera. Means? Close parts of the terrain will have a very fine resolution when rendering, more far away parts have a lower one. With that you can do a whole landscape with only one terrain if you like. In difference to that normal terrains have only one user defined resolution. If you go to close you'll see jaggies probably.
Now I have a question: I am using the Infinite demo, and when I try to stretch a proc terrain to the horizon, it does not "do it's thing". The terrain, besides being totally warped from the stretching (even though I held the shift key to keep it proportional), is also way to short and very jaggy and blurry. Why is that? This goes for Esprit as well, not just infinite.
"Walk down the right back alley in Sin City, and you can find anything."
I think this is exactly what happens when you use a "standard" terrain. When you strech that it becomes jaggy. Try to switch to "procedural" and see what this changes. BTW, if you scale, of course you make everything bigger. You maybe need to work on the terrain function again and change the scale and/or altitude to correct the stretching. Balancing things is the secret, as mostly in real life (too)!
Just to clarify a bit what wabe is talking about, procedural terrains shapes are primarily controlled by a function, so if you scale the terrain itself but not the function you'll just get a larger area of the same function controlled terrain, to adjust the size of the features you need to rescale the terrain and then scale up the function as well, Hope this helps!
OK, I've found it; I thought Vue would automatically calculate the new, enlarged terrain mesh reso. without fiddling with functions. I mean, how would I know how much I should scale up the function when I enlarge the terrain from A to B Vue Units? I'm not a rocket scientist you know! :-))) Anyway I like Vue with its impressive options so I'll buy it soon! Thanks for your support guys! :-)
Hi guys! I would like to know what's the difference between a common terrain and a "procedural" one. (from Vue5i demo) Thanks!
