Tue, Dec 31, 10:44 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 31 9:20 pm)
Subject: Enlarging hands
Prometheus273 ( ) posted Thu, 25 August 2005 at 11:49 PM · edited Tue, 31 December 2024 at 10:39 PM
At the time, I had Poser 4, but I remember reading a Poser 5 book at the book store and there was a section on enlarging hands. If I remember correctly, there is a word that is changed in the CR2 file and when you enlarge the hand, the finger sections will enlarge proportionally. Does anyone have any info on this or another way to enlarge the hands on the Millenium figures?
kuroyume0161 ( ) posted Fri, 26 August 2005 at 12:43 AM
You need to change the hand's "scale" channels to "propagatingScale" (that is: scale, scaleX, scaleY, scaleZ -> propagatingScale, propagatingScaleX, propagatingScaleY, propagatingScaleZ). propagatingScale, most often seen on actor BODY, causes scaling on the body part with these channels to 'propagate' to its children.
 -- Bjarne Stroustrup
Little_Dragon ( ) posted Fri, 26 August 2005 at 3:21 AM · edited Fri, 26 August 2005 at 3:22 AM
Download Furraldo from Free Stuff, if you need an example. I use propagatingScale on his hands, head, and tail.
Message edited on: 08/26/2005 03:22
Anthony Appleyard ( ) posted Fri, 26 August 2005 at 3:47 AM
Attached Link: http://www.buckrogers.demon.co.uk/3d/bighands.zip
![bighands.jpg](http://www.buckrogers.demon.co.uk/3d/thumb/bighands.jpg) At this link.
estherau ( ) posted Fri, 26 August 2005 at 6:57 AM
Thanks Anthony. Are there any problems when you scale them - ie does the wrist joint look or pose funny or anything? Love esther
MY ONLINE COMIC IS NOW LIVE
Anthony Appleyard ( ) posted Fri, 26 August 2005 at 7:47 AM
I don't know.
Gareee ( ) posted Fri, 26 August 2005 at 9:06 AM
Yep. On some figures it isn;t too bad. On others it's horrible. I usually create a smoothing morph, and then create a erc relationship to activate the morph along with the scaling as well. Best case, I didn;t have t odo a thing. Worst case, I created over 45 morphs trying to smooth the transition, and that took about 5 hours of trial and error.
estherau ( ) posted Fri, 26 August 2005 at 9:14 AM
Eeek, no I don't think I'll try it. I'm not that clever. I just feel freak's hands and feet are a little too big, whereas the muscular morphs on David and M3 look funny because they have such cute little wrists and hands and ankles and feet. Love esther
Gareee ( ) posted Fri, 26 August 2005 at 9:18 AM
Yeah for freak you do need morph adjustments. I attempted adding scaling to his hands myself already.
estherau ( ) posted Fri, 26 August 2005 at 9:49 AM
I just don't understand why daz doesn't make a muscular character with slightly less freakish proportions. Love esther
momodot ( ) posted Fri, 26 August 2005 at 10:03 AM
The thing to do if you are editing the .cr2 is search for "actor rhand" then search for "scale scale", change the latter to "propagatingScale scale", then search for actor "rfoot" or "actor lhand" and repeat, etc. You can adjust the wrist ankles with taper but it is better to use a magnet with the zone center write at the end of the wrist or shin and use the zone size to controll how far up the adjustment goes, the further being the smoother. I got this all from pitklad :) Thanks. I use EditPad Lite on my PC since it can open and manipulate 4oMb .cr2 without a shudder. I have also done this propagatingScale on the neck to make "bobble" big heads but it isn't perfect without post-work.
randym77 ( ) posted Fri, 26 August 2005 at 10:26 AM
Does this work for Jessi? She's got such huge hands. Miki's are kind of big, too.
wolf359 ( ) posted Fri, 26 August 2005 at 10:50 AM
The problem with scaling hands is that the wrists must scale proportionaly with them im very glad "spubba" did his freebie for Mike2's hands & Wrists years ago.
My website
Anthony Appleyard ( ) posted Fri, 26 August 2005 at 12:35 PM
To try to make his wrist behave better:- If it is the right hand, do this, else replace "right" by "left". Select the right hand camera. Adjust the view. Select the hand. In the Poser run's menu, select Window, Joint editor. In the Joint Editor window, press the mouse on the white band across the top and select "Twist". That will show like on this image. Use the mouse to drag the red and green ends of the line running along his wrist. That will adjust the blend zone between the hand and the forearm. With the Businessman and my man in overall, the joint zone is likely to be hidden inside the cuff.
