Sun, Feb 9, 2:08 AM CST
Subject: create a posable prop
MANTEKKA ( ) posted Mon, 26 February 2001 at 4:01 PM ยท edited Sun, 09 February 2025 at 2:08 AM
Content Advisory! This message contains nudity, violence
what program or utility, can i use.to create "posables props"? help me....thank to all !!!
ScottA ( ) posted Mon, 26 February 2001 at 5:31 PM
Do you mean make the props? Or do you mean take an existing prop and make it Poseable? ScottA
MANTEKKA ( ) posted Mon, 26 February 2001 at 7:38 PM
I MEAN MAKE PROPS AND MAKE POSEABLE AN EXISTING PROP
ScottA ( ) posted Mon, 26 February 2001 at 8:55 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=221014
Ok. A prop is nothing more than a model that is imported into Poser then saved to the library. You'll need a 3Dmodeling program to make one on your own. There are several to choose from. And some of the most popular ones are listed here at the right under Software Forums. As for making a prop poseable: We talked Spike through the process here on this board a while ago. And it might help explain the process to you if you read it. Click on the link to read the thread. ScottA
JKeller ( ) posted Mon, 26 February 2001 at 9:00 PM
No need to yell. Programs such as Raydream, Carrara, 3DS Max, Lightwave, Truespace, and many more can be used to creat the prop. Basically any program that can be used to model something and export it in a format that Poser can use (.obj and .3ds being the two key formats). Poser4 and a text editor are all you need to make a prop poseable. But the different utilities out there like PHI Builder, cr2Editor and Compose can make the process easier. Hope this helps.
bushi ( ) posted Tue, 27 February 2001 at 2:21 AM
Attached Link: http://bushi3d.com
Take a look at the tutorials on my site. I have some on making props into poseable props using the .phi file method.
mocap ( ) posted Wed, 28 February 2001 at 7:11 PM
If you have P4 and the propack you make any imported prop posable inthe setup room Mocap
