Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=221014
Ok. A prop is nothing more than a model that is imported into Poser then saved to the library. You'll need a 3Dmodeling program to make one on your own. There are several to choose from. And some of the most popular ones are listed here at the right under Software Forums. As for making a prop poseable: We talked Spike through the process here on this board a while ago. And it might help explain the process to you if you read it. Click on the link to read the thread. ScottANo need to yell. Programs such as Raydream, Carrara, 3DS Max, Lightwave, Truespace, and many more can be used to creat the prop. Basically any program that can be used to model something and export it in a format that Poser can use (.obj and .3ds being the two key formats). Poser4 and a text editor are all you need to make a prop poseable. But the different utilities out there like PHI Builder, cr2Editor and Compose can make the process easier. Hope this helps.
Attached Link: http://bushi3d.com
Take a look at the tutorials on my site. I have some on making props into poseable props using the .phi file method.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Content Advisory! This message contains nudity, violence
what program or utility, can i use.to create "posables props"? help me....thank to all !!!
