Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Attached Link: http://forums.cgsociety.org/showthread.php?t=273305&page=3&pp=15
I think they are related to AdamT of CGTalk. Either that or you've accidentally replaced some of Poser's dll files with Aphex Twin mp3s...O_o I've never ever had this problem, and I've been useing P6 for some months now. With Poser 3, 4 and 5 content, as well as Poser 6 of course. I'd say there's something else wrong here. Perhaps an overwritten dll as R_Hatch suggests? I'd check it at least. This isn't right.
The joint parameters of certain figures seem to have enough tolerance left so that they still work in Poser 6.
(Although it still has to be checked if they dont work still BETTER in PP/P5.
So Judy and Don obviously belong to that group that still works, but look what Poser 6 does to NEA:
And NEA is based on Posette and works perfectly fine in PP/P5 and DAZ Studio.
It wasnt even me who discovered this, but someone else reported that my Nellie charcter didnt work in Poser 6.
Also why else if not because of different JP handling would Jessi NOT WORK in PP/P5 and DAZ Studio ???
If my Poser 6 would be "broken", she still should work perfectly fine in the older versions, shouldnt she ?
Looks like Poser 6 was optimized to work best with Poser 6 content and nothing else.
I guess in a not too far future Poser will finally go proprietary.
It would be really nice if one of the Poser Gurus could run some tests to verify my observations.
In the meantime, Ill guess Ill have replace Jessi with her stunt double Jacky for any P5/PP work:
stahlratte
I use M2/V2 even possette,DAZ Troll Apollo MAX and Dork in poser6 posing and animating no problems Mac OSX poser6 SR1
hmmm...the eye problem in P4 would be a hierarcy problem and the problem on the neck looks like the twist joint is wrong... Dork's default cr2 had a simiral problem after a value of twist on the neck,I've fixed that on Domus... I guess this is not any help anyway... :^) *stahlratte Nellie is lovely!!! pitklad
Here is my Nellie character posed in PP/P5:
And here is exactly the same pose applied in Poser 6 :
And to confirm that it is a JP issue, here is Jessi imported and posed in P5:
All her other joints are broken, too, especially the thighs.
So obviously Poser 6 handles the same Joint Parameters different than all previous Poser versions.
This of course makes all Poser 6 content unusable outside P6, and some (or most?) non-Poser 6 content that works perfectly fine in PP/P5 becomes unusuable in Poser 6.
Just for the record, Jessi doesnt bend properly in DAZ-Studio, too, but at least here eyeballs stay attached to the head.
Anyone else has noticed this ?
stahlratte
