Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
You are using the build that had a lot of problems and e-on asked everyone to back up to build 277255.
If you go back to 277255 you will have the export feature you are looking for in Vue Inf. :) Hopeful a new 5.08 build will be out shortly that will have a lot of these problems fixed.
Message edited on: 09/10/2005 17:54
ïÏøçö
As a quick Work-Around you should be able to use the COPY button in the Terrain Editor (near the top left corner) and then PASTE this from the clip-board into your favorite image editor. From there of course you can save it in any file format you use- like PSD, TIF or TGA, which can be re-imported back into the Vue Terrain Editor.
Thanks
