Sat, Dec 28, 4:58 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 28 9:00 am)
Subject: "Ordinal not found" error
msebonyluv ( ) posted Sat, 24 September 2005 at 4:40 PM · edited Sun, 28 July 2024 at 8:48 AM
I just downloaded DAZ Studio 1.0 today and installed it. When I launched it, all I got was an "Ordinal not found" error. Error message says: The ordinal 11 could not be located in the dynamic link library DSOUND.dll. What is causing this error and how can it be fixed. I already put it in the bug tracker, but I thought I'd try to get a response here as well. TIA
bcoleman ( ) posted Sat, 24 September 2005 at 6:16 PM
Sounds like a DirectX error. On windows machines D|S uses DirectX to add sound to animations. Are you using the latest version of DirectX?
More stuff than you can keep track of? Try the free Poser Download Tracker.
msebonyluv ( ) posted Sat, 24 September 2005 at 6:18 PM
How would I be able to tell what version I'm using?
stew451 ( ) posted Sat, 24 September 2005 at 6:30 PM
From the start menu click on "run" when the run dialog window appears type in "dxdiag" without the quotes the last line will tell you the version of directx you are using. Stew
msebonyluv ( ) posted Sat, 24 September 2005 at 6:40 PM
I just downloaded and installed DirectX 9.0 and DAZ Studio has started up. Thank you for your help. :)
stew451 ( ) posted Sat, 24 September 2005 at 8:34 PM
No problem:)
