Never, ever use the PMD or external morph targets options. God only knows why they were set as the defaults.
It's a way of saving your morphs so they can't be used ever again... er, no... It's a way of saving your morphs so they fuck up your files no matter what you do... er, no... It's a way of saving your morphs to somewhere else so you have a greatly reduced filesize. Unless you try to reload it, because - hey, guess what, kids - they got to be saved somewhere! Cynical, moi? Whatever, it's a bag of shite. :D
With Arduinos MPG, look into the cr2 or pz2, since Poser 6 SR1 obviously a hidden statement is required. If you find the hip morphs at actor hip :x , you only have to add after namexxx a new line with hidden 0, you will find the dials after using the morph,
Ulli
With Arduinos MPG, look into the cr2 or pz2, since Poser 6 SR1 obviously a hidden statement is required. If there is no statement, poser interpretes this as hidden 1, without SR1 as hidden 0. If you find the hip morphs at actor hip :x , you only have to add after namexxx a new line with hidden 0, you will find the dials after using the morph,
Ulli
I don't know if this is a rehash of an problem that has been discussed before, but I can't seem to get P6 save the expressions on V3 - let alone anyother morph target setting. It happens with all of my head morphs.when I save and reopen all are reset to zero.
Is this an issue with P6 that anyone else has experienced or do I have a corrupt file in there some where?
Message edited on: 09/29/2005 13:06
