Sat, Jan 25, 4:59 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: P6 problem: expressions for V3
blud ( ) posted Thu, 29 September 2005 at 1:05 PM ยท edited Sat, 18 January 2025 at 1:06 AM
I don't know if this is a rehash of an problem that has been discussed before, but I can't seem to get P6 save the expressions on V3 - let alone anyother morph target setting. It happens with all of my head morphs.when I save and reopen all are reset to zero.
Is this an issue with P6 that anyone else has experienced or do I have a corrupt file in there some where?
Message edited on: 09/29/2005 13:06
blud ( ) posted Thu, 29 September 2005 at 1:31 PM
Turns out that the standard V3 saves fine - all morph targets. However V3 with Andruino's hip replacement (MPG), something is up with the cr2 where it will not save morph target settings. Anyone know of a fix?
randym77 ( ) posted Thu, 29 September 2005 at 1:34 PM
You could try disabling external morphs. That seems to fix a lot of problems with P6.
SamTherapy ( ) posted Thu, 29 September 2005 at 2:39 PM
Never, ever use the PMD or external morph targets options. God only knows why they were set as the defaults.
blud ( ) posted Thu, 29 September 2005 at 2:52 PM
Thank you...Thank you.....and Thank you again. That has solved my issue. Just what the heck is the external morph target thingy anyways? It'll just ruin your day.
SamTherapy ( ) posted Thu, 29 September 2005 at 3:03 PM
It's a way of saving your morphs so they can't be used ever again... er, no... It's a way of saving your morphs so they fuck up your files no matter what you do... er, no... It's a way of saving your morphs to somewhere else so you have a greatly reduced filesize. Unless you try to reload it, because - hey, guess what, kids - they got to be saved somewhere! Cynical, moi? Whatever, it's a bag of shite. :D
Jules53757 ( ) posted Thu, 29 September 2005 at 3:30 PM
With Arduinos MPG, look into the cr2 or pz2, since Poser 6 SR1 obviously a hidden statement is required. If you find the hip morphs at actor hip :x , you only have to add after namexxx a new line with hidden 0, you will find the dials after using the morph,
Ulli
Jules53757 ( ) posted Thu, 29 September 2005 at 3:31 PM
With Arduinos MPG, look into the cr2 or pz2, since Poser 6 SR1 obviously a hidden statement is required. If there is no statement, poser interpretes this as hidden 1, without SR1 as hidden 0. If you find the hip morphs at actor hip :x , you only have to add after namexxx a new line with hidden 0, you will find the dials after using the morph,
Ulli
