Photoshop F.A.Q (Last Updated: 2025 Feb 11 11:38 am)
Attached Link: Simple Brycian Roads
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Oh right, okay. Thanks.
Measure
your mind's height
Thanks, but I've pretty much given up on that tutorial. It was for making roads in Bryce - I just opened Wings3D and made a nice straight road in that (plus a couple of curvy ones just in case) It seems there are quite a few problems in that tut, people have said they've tried it and couldn't get it to work. So as I see no point in banging your head against a brick wall, I stopped... But thanks for the tip, may come in handy some time in the future.
Measure
your mind's height
Try this simple way: 1) Fill the background layer with black&white radial gradient 2) Go to filter-render-difference clouds, press CTRL+F to repeat filter until you see the map that you like. 3) Go to filter-blur-gaussian blur and enter 0,2% press OK. 4) Go to image-adjustment-treshold the image should become black and white, press the down arow and you should get nice natural roads. 5) Duplicate the file by going to image-duplicate and invert it by pressing the CTRL+I. The trick is that one file is youre road and another is mountain around it that match perfect. 6) Make that elevation map on 512x512px, you can enlarge the resolution later in bryce on 1024x1024px or higher. Hope this is not to complicate, its usefull when you want to make waterfalls also ;) Tihomir
Open your mind and share the knowledge!
Is it really? Sounds very handy. Thanks very much. (hastily saving the instructions under "Waterfalls" and "Roads") Lovely. ta.
Measure
your mind's height
I'm trying to follow a tutorial for Bryce but it uses PhotoShop and I don't know that prog very well. An instruction says "Select all in the RGB channel," But I can't find an RGB Channel, and the tut doesn't explain where that is - can anyone help? Fran
Measure your mind's height
Fran's Freestuff
http://www.FranOnTheEdge.com
