Sat, Feb 8, 10:02 AM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Are you up to the challenge??
Subject: Problem following Tutorial
FranOnTheEdge ( ) posted Mon, 10 October 2005 at 6:00 AM ยท edited Sat, 08 February 2025 at 10:02 AM
I'm trying to follow a tutorial for Bryce but it uses PhotoShop and I don't know that prog very well. An instruction says "Select all in the RGB channel," But I can't find an RGB Channel, and the tut doesn't explain where that is - can anyone help? Fran
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
RHaseltine ( ) posted Mon, 10 October 2005 at 9:12 AM
Do you have the Channels palette open (Window>Channels)? If so just do a ctrl-a without chnging anything and you should be fine, assuming that the composite RGB channel and the Red, Green and Blue channels are selected. Ctrl+~ will also select the RGB channel. If you are using Photoshop Elements, rather than the full PS, I don't think you have access to that.
FranOnTheEdge ( ) posted Mon, 10 October 2005 at 12:28 PM
Attached Link: Simple Brycian Roads
Sorry, I should have said, this is what I have:^^^ (see pic) and the link shows the tutorial I'm attempting to follow.
Fran's Freestuff
RHaseltine ( ) posted Mon, 10 October 2005 at 2:09 PM
You have a greyscale image, the tutorial is expecting a colour image. As far as I can see it doesn't matter for the method - just select the grey channel instead of the RGB channel and it should work.
FranOnTheEdge ( ) posted Tue, 11 October 2005 at 12:19 PM
Oh right, okay. Thanks.
Fran's Freestuff
tantarus ( ) posted Mon, 17 October 2005 at 2:28 PM
If you need RGB image go to image-mode-RGB and it will be converted from grayscale to RGB without loosing anything :) Tihomir
Open your mind and share the knowledge!
FranOnTheEdge ( ) posted Tue, 18 October 2005 at 5:29 AM
Thanks, but I've pretty much given up on that tutorial. It was for making roads in Bryce - I just opened Wings3D and made a nice straight road in that (plus a couple of curvy ones just in case) It seems there are quite a few problems in that tut, people have said they've tried it and couldn't get it to work. So as I see no point in banging your head against a brick wall, I stopped... But thanks for the tip, may come in handy some time in the future.
Fran's Freestuff
tantarus ( ) posted Tue, 18 October 2005 at 8:18 AM
Try this simple way: 1) Fill the background layer with black&white radial gradient 2) Go to filter-render-difference clouds, press CTRL+F to repeat filter until you see the map that you like. 3) Go to filter-blur-gaussian blur and enter 0,2% press OK. 4) Go to image-adjustment-treshold the image should become black and white, press the down arow and you should get nice natural roads. 5) Duplicate the file by going to image-duplicate and invert it by pressing the CTRL+I. The trick is that one file is youre road and another is mountain around it that match perfect. 6) Make that elevation map on 512x512px, you can enlarge the resolution later in bryce on 1024x1024px or higher. Hope this is not to complicate, its usefull when you want to make waterfalls also ;) Tihomir
FranOnTheEdge ( ) posted Tue, 18 October 2005 at 3:13 PM
Is it really? Sounds very handy. Thanks very much. (hastily saving the instructions under "Waterfalls" and "Roads") Lovely. ta.
Fran's Freestuff
